Samsung Infrared
The Samsung Infrared integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control a Samsung TV using any infrared transmitter previously configured in Home Assistant.
Because the integration communicates over infrared, it operates in a one-way, fire-and-forget fashion: commands are sent to the TV but there is no feedback channel to confirm the current state of the TV. The integration therefore uses assumed states.
Before setting up the Samsung Infrared integration, you need a working infrared transmitter set up in Home Assistant that exposes an Infrared entity. For example, you can use an ESPHome device with an IR LED pointed at your Samsung TV.
To add the Samsung Infrared device to your Home Assistant instance, use this My button:
  • From the list, select Samsung Infrared.
Device type
The type of Samsung device to control. Currently, only TV is supported.
Infrared transmitter
The infrared transmitter entity to use for sending commands. This must be an entity provided by a hardware integration (such as ESPHome) that has already been set up with an IR transmitter.
Supported devices
The integration supports Samsung TVs that can be controlled via the standard Samsung infrared protocol.
Supported functionality
Entities
The Samsung Infrared integration provides the following entities.
Media player
  • Samsung TV
    • Description: Represents the Samsung TV and allows you to control it via IR commands.
    • Supported features: Turn on, turn off, volume up, volume down, mute, channel up, channel down, play, pause, and stop.
Known limitations
  • The integration uses assumed state, meaning Home Assistant cannot read the actual state of the TV (for example, whether it is on or off, or what the current volume is).
  • Volume control is step-based only; there is no way to set an absolute volume level.
