Pro Breeze
Support for devices by Pro Breeze in Home Assistant is provided by the Midea integration.
Pro Breeze devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Midea integration.
To add the Pro Breeze integration to your Home Assistant instance, use this My button:
From the list, select Pro Breeze.
Usage information
For more documentation on how to use Pro Breeze in Home Assistant, please refer to the Midea integration documentation page.
