Plum Lightpad
Configurable/Dimmable Wi-Fi Lightswitch
- Cloud registered, Local API communication (both RESTful and TCP pushed events)
- Motion Sensor
- Energy Meter
- RGB Glow Ring
- Wi-Fi & Bluetooth connectivity
- Phone Apps for iOS & Android
To add the Plum Lightpad integration to your Home Assistant instance, use this My button:
From the list, select Plum Lightpad.
