Onida Infrared
Support for devices by Onida Infrared in Home Assistant is provided by the Gree Infrared integration.
Onida Infrared devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Gree Infrared integration.
To add the Onida Infrared integration to your Home Assistant instance, use this My button:
  • From the list, select Onida Infrared.
Usage information
For more documentation on how to use Onida Infrared in Home Assistant, please refer to the Gree Infrared integration documentation page.
Note
This page covers Onida-branded air conditioners that use the Gree infrared protocol. Other Onida products are not supported by this integration.
