Nuki Matter
Nuki is a member of the Works with Home Assistant partner program for their Matter products. Nuki is committed to making sure their products are up-to-date and ready to use in Home Assistant.
Nuki Matter devices work locally and integrate seamlessly with the Matter integration in Home Assistant. As all connectivity is happening locally, status updates and controlling your devices happen instantly in Home Assistant.
Learn more about Matter in Home Assistant.
Setting up your Nuki via Matter integrations requires Thread
To use this integration, you need a Thread border router that supports Matter. For more information, refer to the Thread documentation. You can turn your Home Assistant installation into a Thread border router e.g. by using the Home Assistant Connect ZBT-1 or ZBT-2. For more information on setting this up, go to Turning Home Assistant into a Thread border router section
For more information on setting up Matter with Nuki devices, refer to the Nuki Matter setup guide.
