Nuimo controller
The nuimo_controller integration allows you to connect to a Nuimo device for receiving input events and displaying on the LED matrix via the Nuimo SDK for Python on Linux.
To connect to a Nuimo device add the following section to your configuration.yaml file:
nuimo_controller:
mac string (Optional)
Skip discovery and connect to this device address.
name string (Optional, default: None)
To handle more than one device by names, add the name of the device.
Example for testing rotation value and sending to the LED matrix:
automation Nuimo_rotate_right:
  trigger:
    platform: event
    event_type: nuimo_input
    event_data:
      type: ROTATE
  condition:
    condition: template
    value_template: '{{ trigger.event.data.value > 100 }}'
  action:
    service: nuimo_controller.led_matrix
      matrix:
             0000000.
             .000000.
             ..00000.
             .0.0000.
             .00.000.
             .000000.
             .000000.
      interval: 0.5
Troubleshooting:
  • use hcitool lescan to see the mac address of your device
  • allow non-root user access to Bluetooth LE with sudo setcap cap_net_raw+eip $(eval readlink -f $(which python))
  • install the newest version of pygattlib from the repository, either because there is no binary package for your system or the pip version contains errors, with pip install hg+https://bitbucket.org/OscarAcena/pygattlib --target $HOME/.homeassistant/deps. (Dependencies of pygattlib: sudo apt-get install pkg-config libboost-python-dev libboost-thread-dev libbluetooth-dev libglib2.0-dev python-dev) Then invoke Home Assistant with hass --skip-pip.
