Notify.Events
Description
The Notify.Events service is a platform for the notify component.
This platform allows you to quickly configure the distribution of messages between different recipients, no matter how they are used to receiving notifications:
- Telegram
- Viber
- Slack
- Rocket.Chat
- Discord
- Jabber / XMPP
- Webpush
- SMS
- VoiceCall
You can find a full supported messenger list here.
Setting up
To start getting notifications, you need to follow those simple steps:
- Sign up to Notify.Events and create a Channel
- Add Home Assistant source to this channel and get your token
- Add the Notify.Events integration to your installation by adding the following to your
configuration.yaml
file:
notify_events:
token: YOUR_TOKEN
Now you can use notify_events integration as a platform for your notify service, add the following to your configuration.yaml
file:
notify:
- name: NOTIFIER_NAME (e.g. "events")
platform: notify_events
That’s it!
Now you can use the notify.events
service inside your Home Assistant to:
- Send any notifications or alerts
- Distribute events by
level
andpriority
- Attach files and images (local or remote)
- .. and just keep using your favorite messenger to receive them!
Example service call
- service: notify.events
message: "Backyard motion detected!"
level: "warning"
priority: "high"
images:
- name: "local_photo.jpg"
path: "/tmp/backyard_cam/motion.jpg"
- name: "remote_photo.jpg"
url: "https://i.ibb.co/Jt1845X/motion.jpg"
Message optional parameters
The following attributes can be placed inside data
for extended functionality.
Attribute | Description |
title |
Message title. |
level |
For recipients who have differences in the display of messages at different levels, this level will be applied. Available values: verbose , info , notice , warning , error , success . |
priority |
For recipients which supports priority, the message will be highlighted accordingly. Available values: lowest , low , normal , high , highest . |
images |
Array of images to attach (see item properties below). |
files |
Array of files to attach (see item properties below). |
token |
Notify.Events channel token (in case you want to override the channel to get this message to). |
Every item of images and files has the following properties:
Property | Required | Description |
path or url or content
True | File source. |
name |
False | Result file name |
mime_type |
False | File MIME-type |
To use notifications effectively, please see the getting started with automation page.
