Konnected
Konnected is a member of the Made for ESPHome program.
Konnected devices work locally and integrate seamlessly with the ESPHome integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] in Home Assistant. As all connectivity is done locally, status updates and device control from Home Assistant happen instantly.
Support for devices by Konnected in Home Assistant is provided by the ESPHome integration.
Konnected devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the ESPHome integration.
To add the Konnected integration to your Home Assistant instance, use this My button:
Konnected can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Konnected.
Usage information
For more documentation on how to use Konnected in Home Assistant, please refer to the ESPHome integration documentation page.
Supported devices
The following devices are known to be supported by the integration. They are certified under the Works with Home Assistant program.
