History Graph
This integration is deprecated and pending removal in Home Assistant 0.107.0, as it was only used by the old states UI (not our current Lovelace UI).
The history_graph integration will make the UI display a graph similar to the graphs in more-info popups and the history panel. If you want to add history graphs to the Lovelace UI, please check the History Graph Card configuration as it slightly differs from the component.
To use this integration in your installation, add the following to your configuration.yaml file:
# Minimal configuration.yaml entry
history_graph:
  gr1:
    entities:
      - light.ceiling.lights
entities
(string)(Required)
List of entities whose history to show as a graph.
name
(string)(Optional)
Name to display.
Default value:
ID
hours_to_show
(integer)(Optional)
Number of hours to show in the graph.
Default value:
24
refresh
(integer)(Optional)
Number of seconds between graph refreshes. 0 to disable refreshing.
Default value:
0
Full Example
# Full configuration.yaml entry
history_graph:
  gr1:
    entities:
      - light.bed_light
    hours_to_show: 240
    refresh: 60
  gr2:
    entities:
      - sensor.outside_temperature
      - sensor.inside_temperature
    hours_to_show: 120
    # refresh: 0
For sensors to automatically be combined into one graph they need to have exactly the same unit of measurement. This is important if you have, e.g., a unit-less temperature state_topic MQTT sensor and you want to combine this with a weather sensor. unit_of_measurement: of the MQTT sensor then needs to be set to °C.
