HAAS+SOHN
Support for devices by HAAS+SOHN in Home Assistant is provided by the Fumis integration.
HAAS+SOHN devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Fumis integration.
To add the HAAS+SOHN integration to your Home Assistant instance, use this My button:
HAAS+SOHN can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select HAAS+SOHN.
Usage information
For more documentation on how to use HAAS+SOHN in Home Assistant, please refer to the Fumis integration documentation page.
