Evil Genius Labs
This integration allows you to control and monitor the artworks by Evil Genius Labs. Tested with the Fibonacci256.
If the integration is unable to connect, make sure the firmware is up to date.
Adding Evil Genius Labs to your Home Assistant instance can be done via the user interface, by using this My button:
From the list, search and select “Evil Genius Labs”.
