Digital Loggers
Support for devices by Digital Loggers in Home Assistant is provided by the Belkin WeMo integration.
Digital Loggers devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Belkin WeMo integration.
To add the Digital Loggers integration to your Home Assistant instance, use this My button:
Digital Loggers can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select Digital Loggers.
Usage information
For more documentation on how to use Digital Loggers in Home Assistant, please refer to the Belkin WeMo integration documentation page.
The only tested working model is the Pro Switch.
Supported Digital Loggers models emulate the WeMo protocol but this is not automatically enabled. To enable this, find the IP address of your device and log in. Click on External APIs, check the box to allow CoAP, and then click submit.
