Device tracker
The device tracker allows you to track devices in Home Assistant. This can happen by querying your wireless router or by having applications push location info.
Building block integration
This device tracker is a building block integration that cannot be added to your Home Assistant directly but is used and provided by other integrations.
A building block integration differs from the typical integration that connects to a device or service. Instead, other integrations that do integrate a device or service into Home Assistant use this device tracker building block to provide entities, services, and other functionality that you can use in your automations or dashboards.
If one of your integrations features this building block, this page documents the functionality the device tracker building block offers.
Configuring a device_tracker platform
To get started add the following lines to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] (example for Netgear):
# Example configuration.yaml entry for Netgear device
device_tracker:
- platform: netgear
host: IP_ADDRESS
username: YOUR_USERNAME
password: YOUR_PASSWORD
new_device_defaults:
track_new_devices: true
The following optional parameters can be used with any platform:
Device tracker will only look for the following global settings under the configuration of the first configured platform:
Parameter | Default | Description |
interval_seconds |
12 | Seconds between each scan for new devices. This only applies to local device trackers, not applications that push updates. |
consider_home |
180 | Seconds to wait till marking someone as not home after not being seen. This parameter is most useful for households with Apple iOS devices that go into sleep mode while still at home to conserve battery life. iPhones will occasionally drop off the network and then re-appear. consider_home helps prevent false alarms in presence detection when using IP scanners such as Nmap. consider_home accepts various time representations, (e.g., the following all represents 3 minutes: 180 , 0:03 , 0:03:00 ) |
Note that setting track_new_devices: false
will still result in new devices being recorded in known_devices.yaml
, but they won’t be tracked (track: false
The extended example from above would look like the following sample:
device_tracker:
- platform: netgear
host: IP_ADDRESS
interval_seconds: 10
consider_home: 180
Multiple device trackers can be used in parallel, such as Owntracks and Nmap. The state of the device will be determined by the source that reported last.
known_devices.yaml
As of 0.94 known_devices.yaml
is being phased out and no longer used by all trackers. Depending on the integration you use this section may no longer apply. This includes OwnTracks, GeoFency, GPSLogger, Locative and Huawei LTE.
Once device_tracker
is enabled, a file will be created in your configuration dir named known_devices.yaml
. Edit this file to adjust which devices to be tracked.
Here’s an example configuration for a single device:
devicename:
mac: EA:AA:55:E7:C6:94
picture: https://www.home-assistant.io/images/favicon-192x192.png
track: true
In the example above, devicename
refers to the detected name of the device. For example, with nmap
, this will be the MAC address (with byte separators omitted).
name |
Host name or “Unnamed Device” | The friendly name of the device. |
mac |
None | The MAC address of the device. Add this if you are using a network device tracker like Nmap or SNMP. |
picture |
None | A picture that you can use to easily identify the person or device. You can also save the image file in a folder “www” in the same location (can be obtained from developer tools) where you have your configuration.yaml file and just use picture: /local/favicon-192x192.png . The path ‘local’ is mapped to the ‘www’ folder you create. |
icon |
mdi:account | An icon for this device (use as an alternative to picture ). |
gravatar |
None | An email address for the device’s owner. If provided, it will override picture . |
track |
[uses platform setting] | If yes /on /true then the device will be tracked. Otherwise its location and state will not update. |
consider_home |
[uses platform setting] | Seconds to wait till marking someone as not home after not being seen. Allows you to override the global consider_home setting from the platform configuration on a per device level. |
Device states
The state of your tracked device will be 'home'
if it is in the home zone, detected by your network or Bluetooth based presence detection. If you’re using a presence detection method that includes coordinates then when it’s in a zone the state will be the name of the zone (case sensitive). When a device isn’t at home and isn’t in any zone, the state will be 'not_home'
device_tracker.see service
The device_tracker.see
service can be used to manually update the state of a device tracker:
Service data attribute | Optional | Description |
dev_id |
no | The object_id , for example tardis for device_tracker.tardis
location_name |
yes | The location, home , not_home , or the name of the zone |
host_name |
yes | The hostname of the device tracker |
mac |
yes | The MAC address of the entity (only specify if you’re updating a network based tracker) |
gps |
yes | If you’re providing a location, for example [51.513845, -0.100539]
gps_accuracy |
yes | The accuracy of the GPS fix |
battery |
yes | The battery level of the device |
