Denon RS-232
The Denon RS-232 integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control Denon receivers by connecting to their RS-232 serial port. Because Home Assistant talks straight to the receiver, you get local control with push-based state updates.
This integration requires a serial connection to your device. You can connect the device to a serial port on the system that runs Home Assistant, or reach it over your network with an ESPHome serial proxy. For more details, refer to setting up a serial connection.
- A Denon receiver that supports control over its RS-232 serial port.
To add the Denon RS-232 hub to your Home Assistant instance, use this My button:
From the list, select Denon RS-232.
Supported functionality
The integration adds media player entities as an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] for your receiver.
Media player controls
For supported receivers, you can use Home Assistant to:
- Turn the receiver on and off
- Change the volume
- Mute and unmute the main zone
- Select the input source
- Select a tuner preset or FM frequency
Zones
If your receiver supports additional zones, Home Assistant adds separate media player entities for those zones.
- Main zone
- Zone 2
- Zone 3
The available zones depend on your receiver model.
Source selection
The available input sources depend on the receiver model you select during setup.
Selecting tuner presets and frequencies
On the main zone, you can tune the receiver to a stored tuner preset or directly to an FM frequency. This works from the media browser, which lists the tuner presets, or by calling the media_player.play_media action with a media_content_type of channel.
The media_content_id can be a preset name from A1 through G8:
entity_id: media_player.denon_avr
media_content_type: channel
media_content_id: "A1"
It can also be tuned to an FM frequency between 8750 (87.50 MHz) and 10800 (108.00 MHz):
media_content_id: "9870"
