Chess.com
The Chess.com integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to monitor your Chess.com statistics in Home Assistant.
To add the Chess.com service to your Home Assistant instance, use this My button:
From the list, select Chess.com.
Supported functionality
Entities
The Chess.com integration provides the following entities.
Sensors
- Followers: The number of followers of your Chess.com account.
For each game mode you have played (daily, rapid, bullet, blitz, and daily Chess960), the following sensors are provided:
- Rating: The current rating for that game mode.
- Games won: The total number of games won in that game mode.
- Games lost: The total number of games lost in that game mode.
- Games drawn: The total number of games drawn in that game mode.
Sensors for game modes that you have not played yet are not created.
Data updates
The integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] the Chess.com API every hour to update sensor data.
menu. Then, select Delete.
