Chef iQ
The Chef iQ integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you read the temperatures from Chef iQ wireless cooking probes directly over Bluetooth Low Energy. No cloud account, base station, or hub is required: the probe broadcasts its readings and Home Assistant listens passively.
Supported devices
The following Chef iQ wireless probe is supported:
- Chef iQ Smart Wireless Meat Thermometer (CQ60)
The iQ Sense base station broadcasts under the same Bluetooth identifier, but it is a Wi-Fi appliance rather than a passive probe and is not supported by this integration.
This integration requires a working Bluetooth setup, either a local Bluetooth adapter or an ESPHome Bluetooth proxy. The probe is battery-powered and only broadcasts while it is awake, so make sure it is awake (for example, by taking it off its charging dock) before adding it.
To add the Chef iQ device to your Home Assistant instance, use this My button:
From the list, select Chef iQ.
Supported functionality
The Chef iQ integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more].
Sensors
A probe exposes the following sensors:
- Food temperature: the food (internal) temperature at the probe tip.
- Ambient temperature: the ambient (cooking environment) temperature.
- Probe tip 1 through 4 temperatures: the temperatures measured along the probe shaft (disabled by default).
- Battery: the probe battery percentage.
- SoC temperature: the temperature of the probe’s system-on-chip (SoC), its internal electronics (diagnostic, disabled by default).
- Signal strength: the Bluetooth signal strength (diagnostic, disabled by default).
Use cases
- Follow a long cook from anywhere in the house: put the food and ambient temperatures on a dashboard and let Home Assistant tell you when the roast reaches its target, instead of walking back to the grill or keeping your phone awake.
- Catch a dying fire or a runaway smoker: get a notification when the ambient temperature drifts out of the range you want, even when you are nowhere near the probe.
- Keep a record of your cooks: the temperature history shows how the food and the cooking environment progressed, which helps to repeat a good cook or fix a bad one.
- Know when to charge: get a reminder when the probe battery runs low, so it is ready for the next cook.
Examples
The entity IDs below belong to a probe named CQ60 079A; replace them with the ones of your probe. The thresholds are in °C. If your Home Assistant uses °F, the sensors report °F as well, so use 145 for the roast and 212 to 275 for the smoker range. The notifications go to a phone running the Home Assistant Companion app through its notify.mobile_app_<device> action; replace notify.mobile_app_phone with the action for your phone. If your destination is a notify entity instead, use the notify.send_message action with that entity as its target, since the action alone does not pick a destination.
Automation: Notify when the food is done
Waiting next to the grill is no fun. Send a notification when the food core temperature reaches the target, 63 °C for a roast in this example.
Trigger: Numeric state
Entity: Food temperature (
sensor.cq60_079a_food_temperature) -
Above:
63
Action: Notifications: Send a notification via mobile_app_phone (
notify.mobile_app_phone)-
Message:
Roast is at {% raw %}{{ states('sensor.cq60_079a_food_temperature') }}{% endraw %}°. Time to take it out.
Message:
YAML example for notifying when the food is done
alias: "Roast is done"
triggers:
- trigger: numeric_state
entity_id: sensor.cq60_079a_food_temperature
above: 63
actions:
- action: notify.mobile_app_phone
message: >
Roast is at {{ states('sensor.cq60_079a_food_temperature') }}°.
Automation: Warn when the smoker drifts out of range
A fire that dies down or runs away ruins a long cook. Send a notification when the ambient temperature stays below or above your smoking range for five minutes.
Entity: Ambient temperature (
sensor.cq60_079a_ambient_temperature) -
Below:
100 - For: 5 minutes
Above:
135 - For: 5 minutes
Message:
The smoker is out of range. Check the fire.
Message:
YAML example for warning when the smoker drifts out of range
alias: "Smoker temperature out of range"
triggers:
entity_id: sensor.cq60_079a_ambient_temperature
below: 100
for: "00:05:00"
above: 135
for: "00:05:00"
actions:
message: "The smoker is out of range. Check the fire."
Automation: Remind yourself to charge the probe
A flat probe on cook day is annoying. Send a notification when the battery drops below 20%.
Entity: Battery (
sensor.cq60_079a_battery) -
Below:
20
Entity: Battery (
Message:
The meat probe battery is below 20%. Put it back on its dock.
Message:
YAML example for reminding yourself to charge the probe
alias: "Charge the meat probe"
triggers:
entity_id: sensor.cq60_079a_battery
below: 20
actions:
message: >
Data updates
The integration is passive: it never polls or connects to the probe. Entities update whenever Home Assistant receives one of the probe’s Bluetooth advertisements, which the probe broadcasts while it is awake. The battery level and SoC temperature are sent in a separate advertisement from the cooking temperatures (food, ambient, and probe tip), so they may appear a few seconds later after setup. When the probe stops broadcasting, for example once it is docked and asleep, no new readings arrive until it is seen again.
Known limitations
The integration is passive and read-only. It reports the probe’s broadcast readings, but cannot start cooks, set target temperatures, or change probe settings. Those features require the Chef iQ app.
The probe is not discovered
If the device is not discovered, try the following:
- Make sure that the probe is awake and broadcasting (take it off its dock).
- Make sure your Bluetooth adapter or proxy is in range of the probe.
- Make sure the Bluetooth integration is set up and working.
The sensors are unavailable
The probe only broadcasts while it is awake. Once it has stopped broadcasting for a few minutes, for example because it is back on its dock, its sensors become unavailable. They recover on their own with the probe’s next advertisement, so wake the probe or bring it back into range of a Bluetooth adapter or proxy.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
