MySensors Binary Sensor
Integrates MySensors binary sensors into Home Assistant. See the main integration for configuration instructions.
The following sensor types are supported:
MySensors version 1.4 and higher
S_TYPE V_TYPE
S_DOOR V_TRIPPED
S_MOTION V_TRIPPED
S_SMOKE V_TRIPPED
MySensors version 1.5 and higher
S_TYPE V_TYPE
S_SPRINKLER V_TRIPPED
S_WATER_LEAK V_TRIPPED
S_SOUND V_TRIPPED
S_VIBRATION V_TRIPPED
S_MOISTURE V_TRIPPED
For more information, visit the serial API of MySensors.
Example sketch
 * Documentation: https://www.mysensors.org
 * Support Forum: https://forum.mysensors.org
 * https://www.mysensors.org/build/binary
#include <MySensor.h>
#include <SPI.h>
#include <Bounce2.h>
#define SN "BinarySensor"
#define SV "1.0"
#define CHILD_ID 1
#define BUTTON_PIN 3  // Arduino Digital I/O pin for button/reed switch.
MySensor gw;
Bounce debouncer = Bounce();
MyMessage msg(CHILD_ID, V_TRIPPED);
void setup()
  gw.begin();
  gw.sendSketchInfo(SN, SV);
  // Setup the button.
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  // After setting up the button, setup debouncer.
  debouncer.attach(BUTTON_PIN);
  debouncer.interval(5);
  gw.present(CHILD_ID, S_DOOR);
  gw.send(msg.set(0));
void loop()
  if (debouncer.update()) {
    // Get the update value.
    int value = debouncer.read();
    // Send in the new value.
    gw.send(msg.set(value == LOW ? 1 : 0));
