August Bluetooth
Integrates August locks over Bluetooth into Home Assistant.
Following Assa Abloy, Yale’s parent company, purchasing August in 2017, most newer devices use the Yale Access branding.
Support for devices by August Bluetooth in Home Assistant is provided by the Yale Access Bluetooth integration.
August Bluetooth devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Yale Access Bluetooth integration.
To add the August Bluetooth integration to your Home Assistant instance, use this My button:
From the list, select August Bluetooth.
Usage information
For more documentation on how to use August Bluetooth in Home Assistant, please refer to the Yale Access Bluetooth integration documentation page.
