Actron Air
The Actron Air integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control Actron Air
You must have an Actron Air air conditioner with the Neo or Que controller, an active internet connection, and be registered to an email address.
Supported devices
This integration supports the Actron Air Neo and Que controllers.
To add the Actron Air integration to your Home Assistant instance, use this My button:
Actron Air can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Actron Air.
Supported functionality
Climate
The integration will create a climate entity for the main air conditioning system found and for each zone. The main air conditioner unit will be reflected based on the name in the Actron Air app. You can set the temperature, operation mode, and fan speed through this entity.
Each zone will be reflected as a separate climate entity. You can set the temperature and operation mode per zone (if supported by your air conditioner).
menu. Then, select Delete.
