System Health
The System Health integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides an API to offer information on the system and its components. It also allows to run diagnostic tools to diagnose problems.
System Health integration data can be viewed at Settings -> System -> Repairs -> System Information in the three dots menu (top right).
Data includes information about your system architecture, operating system and version, Home Assistant installation type and version, Python version, frontend version, the number of Dashboards and Views you have, and more.
This integration is by default enabled, unless you’ve disabled or removed the default_config: line from your configuration. If that is the case, the following example shows you how to enable this integration manually:
system_health:
