Change device type of a switch
The Change device type of a switch helper integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you convert any Home Assistant switch into a Home Assistant Light, Cover, Fan, Lock, Siren, or Valve.
In Home Assistant’s world, a wall plug is a switch. And while that is correct for a wall plug in general, those plugs are often used with e.g, a light fixture or a fan. General-purpose relays are similar, as they are sometimes used for things like locks or garage doors.
Using the Change device type of a switch helper integration, you can convert those switches into the entity types that best matches your use case.
To add the Switch as X helper to your Home Assistant instance, use this My button:
  • At the top of the screen, select the tab: Helpers.
  • In the bottom right corner, select the Create helper button.
  • From the list, select Switch as X.
Switch entity
The switch entity you want to convert into something else.
Type
The type of entity you want the switch to become.
Change device type of a switch from the existing entity
Where compatible, Change device type of a switch will appear on entity properties. A list of entities can be found in Settings > Devices & services > Entities.
Entity properties example
