Simply Automated
Support for devices by Simply Automated in Home Assistant is provided by the Universal Powerline Bus (UPB) integration.
Simply Automated devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Universal Powerline Bus (UPB) integration.
To add the Simply Automated integration to your Home Assistant instance, use this My button:
  • From the list, select Simply Automated.
Usage information
For more documentation on how to use Simply Automated in Home Assistant, please refer to the Universal Powerline Bus (UPB) integration documentation page.
