SFR Box
The SFR Box integration offers integration with the SFR broadband router.
This integration provides the following platforms:
- Binary sensors - such as ADSL status.
- Buttons - such as reboot.
- Sensors - such as ADSL line status, attenuation, noise and data rate.
To add the SFR Box device to your Home Assistant instance, use this My button:
From the list, select SFR Box.
The username for accessing your SFR box’s web interface. The default is ‘admin’.
Compatibility
The integration uses the REST API, which is known to be available on models NB4, NB5, NB6, NB6V, and NB6VAC.
However, NCC models do not appear to expose this REST API, and are therefore unsupported by the integration.
menu. Then, select Delete.
