Seven Segments OCR
The seven_segments image processing platform allows you to read physical seven segments displays through Home Assistant. ssocr is used to extract the value shown on the display which is observed by a camera.
Home Assistant Core Requirements
If you are running Home Assistant Core in a Python virtual environment, you need to ensure the following requirements are met.
ssocr needs to be available on your system. Check the installation instruction below:
sudo dnf -y install imlib2-devel # Fedora
sudo apt install libimlib2-dev # Ubuntu
brew install imlib2 # macOS
git clone https://github.com/auerswal/ssocr.git
cd ssocr
make
sudo make PREFIX=/usr install # On most systems
make deb # (Optional) This allows you to make a deb so that you apt is aware of ssocr
To enable the OCR of a seven segment display in your installation, add the following to your configuration.yaml file:
image_processing:
  - platform: seven_segments
    source:
      - entity_id: camera.seven_segments
ssocr_bin
(string)(Optional)
The command line tool ssocr. Set it if you use a different name for the executable.
Default value:
ssocr
x_position
(integer)(Optional)
X coordinate of the upper left corner of the area to crop.
Default value:
0
y_position
(integer)(Optional)
Y coordinate of the upper left corner of the area to crop.
Default value:
0
height
(integer)(Optional)
Height of the area to crop.
Default value:
0
width
(integer)(Optional)
Width of the area to crop.
Default value:
0
rotate
(integer)(Optional)
Rotation of the image.
Default value:
0
threshold
(integer)(Optional)
Threshold for the difference between the digits and the background.
Default value:
0
digits
(integer)(Optional)
Number of digits in the display.
Default value:
-1
extra_arguments
(string)(Optional)
Other arguments to use. Like -D, dilation, erosion, greyscale, make_mono, etc.
source
(list)(Required)
List of image sources.
entity_id
(string)(Required)
A camera entity id to get picture from.
name
(string)(Optional)
This parameter allows you to override the name of your image_processing entity.
Setup process
It’s suggested that the first attempt to determine the needed parameters is using ssocr directly. This may require a couple of iterations to get the result
This would lead to the following entry for the configuration.yaml file:
camera:
  - platform: local_file
    file_path: /home/homeassistant/.homeassistant/seven-seg.png
image_processing:
    x_position: 390
    y_position: 250
    height: 280
    width: 490
    threshold: 20
    digits: 4
    source:
With the help of a template sensor, the value can be shown as badge.
  - platform: template
    sensors:
      power_meter:
        value_template: '{{ states('image_processing.sevensegment_ocr_seven_segments') }}'
        friendly_name: 'Ampere'
        unit_of_measurement: 'A'
