Raspberry Pi RF
The rpi_rf
switch platform allows you to control devices over 433/315MHz LPD/SRD signals with generic low-cost GPIO RF modules on a Raspberry Pi.
Interoperable with codes sniffed via the rpi-rf module or rc-switch. For more info see the PyPi module description: rpi-rf.
To enable, add the following to your configuration.yaml
switch:
- platform: rpi_rf
gpio: 17
switches:
bedroom_light:
code_on: 1234567
code_off: 1234568
ambilight:
pulselength: 200
code_on: 987654
code_off: 133742
living_room_light:
protocol: 5
code_on: 654321,565874,233555,149874
code_off: 654320,565873,233554,149873
signal_repetitions: 15
The array that contains all switches.
Name of the switch. Multiple entries are possible.
Decimal code(s) to switch the device on. To run multiple codes in a sequence, separate the individual codes with commas ‘,’.
Decimal code(s) to switch the device off. To run multiple codes in a sequence, separate the individual codes with commas ‘,’.
Help us to improve our documentation
