PiFace Digital I/O (PFIO)
The rpi_pfio integration is the base for all related PiFace Digital I/O (PFIO) platforms in Home Assistant. There is no setup needed for the integration itself; for the platforms, please check their corresponding pages.
Set the jumpers on the PiFace board for address 0 (JP1: 1-2, JP2: 1-2).
Using with the Home Assistant Operating System
Note that the PiFace Digital 2 uses the Raspberry Pi SPI port, which is disabled by default when using the Home Assistant Operating System. You must mount the SD card on another computer and access the boot partition on the card. Edit the config.txt file and add the line dtparam=spi=on to the end.
This should enable SPI when the Home Assistant Operating System is booted to access the PiFace Digital 2 board.
Binary Sensor
The rpi_pfio binary sensor platform allows you to read sensor values of the PiFace Digital I/O .
To use your PiFace Digital I/O module in your installation, add the following to your configuration.yaml file:
binary_sensor:
  - platform: rpi_pfio
    ports:
      0:
        invert_logic: true
      1:
        settle_time: 50
portsmapRequired
List of used ports.
nummapRequired
The port number.
namestringRequired
The port name.
settle_timeinteger(Optional, default: 20)
The time in milliseconds for port debouncing.
invert_logicboolean(Optional)
If true, inverts the output logic to ACTIVE LOW.
Default:
false (ACTIVE HIGH)
Switch
The rpi_pfio switch platform allows you to control the PiFace Digital I/O module.
switch:
    ports:
      0:
        invert_logic: true
      1:
portslistRequired
Array of used ports.
numlistRequired
Port number.
namestringRequired
Port name.
invert_logicboolean(Optional, default: false)
