pigpio Daemon PWM LED
The rpi_gpio_pwm platform allows to control multiple lights using pulse-width modulation, for example LED strips. It supports one-color, RGB and RGBW LEDs driven by GPIOs of a Raspberry Pi (same host or remote) or a PCA9685 controller.
For controlling the GPIOs, the platform connects to the pigpio-daemon, which must be running. On Raspbian Jessie 2016-05-10 or newer the pigpio library is already included. On other operating systems it needs to be installed first (see installation instructions).
To enable this platform, add the following lines to your configuration.yaml:
light:
  - platform: rpi_gpio_pwm
    leds:
      - name: Lightstrip Cupboard
        driver: gpio
        pins: [17]
        type: simple
leds
(list)(Required)
Can contain multiple LEDs.
name
(string)(Required)
The name of the LED.
driver
(string)(Required)
The driver which controls the LED. Choose either gpio or pca9685.
pins
(list | integer)(Required)
The pins connected to the LED as a list. The order of pins is determined by the specified type.
type
(string)(Required)
The type of LED. Choose either rgb, rgbw or simple.
freq
(integer)(Optional)
The PWM frequency.
Default value:
200
address
(string)(Optional)
The address of the PCA9685 driver.
Default value:
64
host
(string)(Optional)
The remote host address for the GPIO driver.
Examples
RGB LED connected to PCA9685 controller
This example uses a PCA9685 controller to control a RGB LED.
light:
    leds:
      - name: TV Backlight
        driver: pca9685
        pins: [0, 1, 2] # [R, G, B]
        type: rgb
RGBW LED connected to PCA9685 controller
This example uses a PCA9685 controller to interact with a RGBW LED.
light:
    leds:
      - name: Lightstrip Desk
        driver: pca9685
        pins: [3, 4, 5, 6] # [R, G, B, W]
        type: rgbw
RGB LED connected to the GPIO pins of an remote Raspberry Pi.
On the Raspberry Pi the pigpio daemon is running on the default port 6666.
light:
    leds:
      - name: Lightstrip Sideboard
        driver: gpio
        host: 192.168.0.66
