Xiaomi IR Remote
The xiaomi miio remote platform allows you to send IR commands from your Xiaomi IR Remote (ChuangmiIr).
Setup
Please follow the instructions on Retrieving the Access Token to get the API token to use in the configuration.yaml file.
Configuring the Platform
To add a Xiaomi IR Remote to your installation, add the following to your configuration.yaml file:
remote:
  - platform: xiaomi_miio
    host: 192.168.42.42
    token: YOUR_TOKEN
host
(string)(Required)
The IP of your remote.
token
(string)(Required)
The API token of your remote.
name
(string)(Optional)
The name of your remote.
slot
(integer)(Optional)
The slot used to save learned command.
Default value:
1
timeout
(integer)(Optional)
Timeout for learning a new command.
Default value:
30
commands
(map)(Optional)
A list of commands
command
(list)(Required)
A list of commands as raw (learned command) or pronto hex code.
Full Configuration
remote:
    host: 192.168.42.42
    token: YOUR_TOKEN
    slot: 1
    timeout: 30
    commands:
      activate_towel_heater:
        command:
          - raw:base64:[optional_frequency]
      read_bad_poem:
        command:
          - pronto:pronto_hex:[optional_repeat]
Add command as entity button in Lovelace UI
type: entity-button
tap_action:
  action: call-service
  service: remote.send_command
  service_data:
    command: activate_towel_heater
    entity_id: remote.xiaomi_miio_ir
hold_action:
  action: more-info
show_icon: true
show_name: true
entity: remote.xiaomi_miio_ir
icon: 'mdi:radiator'
name: Activate Towel Heater
Use named commands to create UI buttons
script:
  towel_heater:
    sequence:
      - service: remote.send_command
        entity_id: 'remote.bathroom_remote'
          command:
            - 'activate_towel_heater'
  please_cover_your_ears:
    sequence:
          command:
            - 'read_bad_poem'
Command Types
The Xiaomi IR Remote Platform currently supports two different formats for IR codes.
Raw
A raw command is a command learned from xiaomi_miio.remote_learn_command.
A raw command is defined as in the following example:
raw:Z6UFANEAAAAjAQAAAwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQIAE=
with an optional last parameter of frequency:
raw:Z6UFANEAAAAjAQAAAwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQIAE=:38400
Pronto Hex Code
A pronto hex code is a hex code often supplied by the device manufacturer.
A pronto hex code is defined as in the following example:
pronto:0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0623 015B 0057 0016 0E6E
with an optional last parameter of repeats (required by some devices):
pronto:0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0623 015B 0057 0016 0E6E:2
Note there are at least 4 versions of the Xiaomi IR Remote (ChuangmiIr) which can be recognized by their default hostname:
  • chuangmi.ir.v2
  • chuangmi.remote.h102a03
  • chuangmi.remote.v2
  • chuangmi.remote.h102c01
For now, pronto hex codes only work on the first version (chuangmi.ir.v2).
Platform Services
The Xiaomi IR Remote Platform registers four services.
remote.send_command
Allows sending either named commands using an identifier or sending commands as one of the two types defined in Command Types.
Used to learn new commands.
Use the entity_id of the Xiaomi IR Remote to start a learning process.
slot and timeout can be specified, but multiple commands learned to the same slot can still be sent using remote.send_command even if they are overwritten.
After learning the command the base64 string can be found as a notification in Overview, the string can be copied by left clicking on the string and choose the copy option.
xiaomi_miio.remote_set_led_on
Used to turn remote’s blue LED on.
xiaomi_miio.remote_set_led_off
Used to turn remote’s blue LED off.
