Raven Rock MFG
Support for devices by Raven Rock MFG in Home Assistant is provided by the Motionblinds integration.
Raven Rock MFG devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Motionblinds integration.
To add the Raven Rock MFG integration to your Home Assistant instance, use this My button:
Raven Rock MFG can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select Raven Rock MFG.
Usage information
For more documentation on how to use Raven Rock MFG in Home Assistant, please refer to the Motionblinds integration documentation page.
