Radio Browser
The Radio Browser integration allows you to use the directory of radio stations collected on Radio Browser in Home Assistant.
All radio stations can be browsed and played via the Media panel in Home Assistant.
Additionally, when creating automations, the “Play Media” action can be used to pick a station from the directory. This makes it possible to create an automation that e.g., starts playing your favorite radio station on your Cast devices.
Adding Radio Browser to your Home Assistant instance can be done via the user interface, by using this My button:
From the list, search and select “Radio Browser”.
