QVR Pro
QVR Pro allows you to create an independent and expandable surveillance environment on your QNAP NAS. The qvr_pro integration allows you to view your QVR Pro channels in Home Assistant.
Currently, only cameras are supported by this integration.
To enable QVR Pro integration, add the following to your configuration.yaml file:
qvr_pro:
  host: YOUR_HOST
  username: YOUR_USERNAME
  password: YOUR_PASSWORD
host string Required
The IP address where QVR Pro is accessible.
username string Required
The username for accessing your QVR account.
password string Required
The password for accessing your QVR account.
port integer (Optional, default: 8080)
The port where QVR accepts connections.
exclude_channels list (Optional)
Comma separated list of channel numbers to be excluded.
Enabling the QVR Pro camera platform will add all QVR Pro channels by default. Please see exclude_channels if you would like to exclude specific channels from showing up in Home Assistant.
The QVR Pro user must have Surveillance Management permission.
