Quantum Gateway
The quantum_gateway device tracker platform offers presence detection by looking at devices connected to a Verizon Fios gateway.
It was tested with a Verizon Fios-G1100 and G3100 Quantum Gateway.
To use a Verizon Fios Quantum Gateway in your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file, restart Home Assistant to apply the changes. To view the changes, go to Settings > Devices & services > Entities.
device_tracker:
  - platform: quantum_gateway
    host: 192.168.1.1
    password: YOUR_PASSWORD
host string (Optional, default: myfiosgateway.com)
The IP address of your router, e.g., 192.168.1.1.
password string Required
The password for the admin user. The default password may be printed on the gateway itself.
ssl boolean (Optional, default: true)
Use HTTPS when connecting to gateway. New firmware may require HTTPS while older may require this to be False.
