iframe Panel
The panel_iframe support allows you to add additional panels to your Home Assistant frontend. The panels are listed in the sidebar and can contain external resources like the web frontend of your router, your monitoring system, or your media server.
If you are accessing Home Assistant over HTTPS using SSL, you cannot access HTTP sites through an iframe panel.
To enable Panel iFrames in your installation, add the following to your configuration.yaml file:
panel_iframe:
  router:
    title: "Router"
    url: "http://192.168.1.1"
  fridge:
    title: "Fridge"
    url: "http://192.168.1.5"
    icon: mdi:fridge
  otherapp:
    title: "Other App"
    url: "/otherapp"
    require_admin: true
panel_iframe map Required
Enables the panel_iframe component. Only allowed once.
panel_name map Required
Name of the panel. Only allowed once.
title string Required
Friendly title for the panel. Will be used in the sidebar.
url string Required
The absolute URL or relative URL with an absolute path to open.
icon icon (Optional)
Icon for entry.
require_admin boolean (Optional, default: false)
If admin access is required to see this iframe.
Do not create one that is named lovelace it will overwrite Lovelace causing it to never load.
