Ness Alarm
The ness_alarm
[Learn more] will allow Home Assistant users who own a Ness D8x/D16x alarm system to leverage their alarm system and its sensors to provide Home Assistant with information about their homes. Connectivity between Home Assistant and the alarm is accomplished through a IP232 module that must be connected to the alarm.
- Binary sensor: Reports on zone statuses
- Alarm control panel: Reports on alarm status, and can be used to arm/disarm the system
The module communicates via the Ness D8x/D16x ASCII protocol
A ness_alarm
section must be present in the configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file and contain the following options as required:
ness_alarm:
host: alarm.local
port: 2401
zones:
- name: Garage
- name: Storeroom
- name: Kitchen
- name: Front Entrance
- name: Front Door
type: door
Time interval between updates. Supported formats: scan_interval: 'HH:MM:SS'
, scan_interval: 'HH:MM'
and Time period dictionary (see example below).
Infer the disarmed arming state only via system status events. This works around a bug with some panels (<v5.8
) which emit update.status = []
when they are armed.
List of zones to add
The zone type. Can be any binary_sensor device class.
Time period dictionary example
scan_interval:
# At least one of these must be specified:
days: 0
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
Services
Service aux
Trigger an aux output. This requires PCB version 7.8 or higher.
Service data attribute | Optional | Description |
output_id |
No | The aux output you wish to change. A number from 1-4. |
state |
Yes | The On/Off State, represented as true/false. Default is true. If P14xE 8E is enabled then a value of true will pulse output x for the time specified in P14(x+4)E. |
Service panic
Trigger a panic
code |
No | The user code to use to trigger the panic. |
