Möhlenhoff Alpha 2
The Möhlenhoff Alpha 2 integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control a Möhlenhoff Alpha 2
temperature control system.
Please make sure the base station is turned on and connected to your local network.
To add the Möhlenhoff Alpha 2 integration to your Home Assistant instance, use this My button:
From the list, select Möhlenhoff Alpha 2.
Climate
The climate platform provides current and target temperature information, HVAC and preset mode.
A climate entity will be created for each area. The name of the entity is taken from the name of the heat area defined in the Alpha 2 base station.
The state is polled from the base every 60 seconds.
Please note that after changing the temperature in Home Assistant, it may take up to 10 minutes for your room control units to display these changes.
Actions
This integration supports the following actions (see Climate).
set_temperature-
set_hvac_mode-
heatfor heating mode -
coolfor cooling mode
set_preset_mode-
autoenable schedule based operation -
dayenable day mode -
nightenable night mode
