Phone Modem
The modem_callerid
integration uses an available modem for collecting caller ID information. It requires a Hayes AT compatible modem that supports caller ID detection (via AT+VCID=1). Usually any modem that uses a CX93001 will support this.
When the sensor detects a new call, its state changes to ‘ring’ for each ring and ‘callerid’ when caller id information is received. It returns to ‘idle’ once ringing stops. The state event includes an attribute payload that includes the time of the call, name, and number.
This integration also offers a button to pick up and then hang up the call to properly reject it (via ATA and ATH).
Adding Phone Modem to your Home Assistant instance can be done via the user interface, by using this My button:
From the list, search and select “Phone Modem”.
Examples
An example automation:
automation:
- alias: Notify CallerID
trigger:
platform: state
entity_id: sensor.phone_modem
to: "callerid"
action:
service: notify.notify
message: "Call from {{ state_attr('sensor.phone_modem', 'cid_name') }} at {{ state_attr('sensor.phone_modem', 'cid_number') }} "
- alias: Notify CallerID webui
trigger:
platform: state
to: "callerid"
action:
service: persistent_notification.create
title: "Call from"
message: "{{ state_attr('sensor.phone_modem', 'cid_time').strftime("%I:%M %p") }} {{ state_attr('sensor.phone_modem', 'cid_name') }} {{ state_attr('sensor.phone_modem', 'cid_number') }} "
- alias: Say CallerID
trigger:
platform: state
to: "callerid"
action:
service: tts.google_say
message: "Call from {{ state_attr('sensor.phone_modem', 'cid_name') }}"
