Xiaomi Mijia BLE Temperature and Humidity Sensor
The mitemp_bt sensor platform allows one to monitor room temperature and humidity. The Xiaomi Mijia BLE Temperature and Humidity sensor with LCD is a small Bluetooth Low Energy device that monitors the room temperature and humidity. As only a single BLE device can be polled at the same time, the library employs locking to make sure this is the case.
Installation
Depending on the operating system you’re running, you have to configure the proper Bluetooth backend on your system:
  • On Hass.io: mitemp_bt will work out of the box as long as the host supports Bluetooth (like the Raspberry Pi does).
  • On a generic Docker installation: Works out of the box with --net=host and properly configured Bluetooth on the host.
  • On other Linux systems:
    • Preferred solution: Install the bluepy and btlewrap library (via pip). When using a virtual environment, make sure to use install the library in the right one.
    • Fallback solution: Install btlewrap library (via pip) and gatttool via your package manager. Depending on the distribution, the package name might be: bluez, bluetooth or bluez-deprecated.
  • Windows and MacOS are currently not supported by the btlewrap library.
Start a scan to determine the MAC addresses of the sensor:
$ sudo hcitool lescan
LE Scan ...
4C:65:A8:D2:31:7F MJ_HT_V1
Or if your distribution is using bluetoothctl:
$ bluetoothctl
[bluetooth]# scan on
Discovery started
[CHG] Controller XX:XX:XX:XX:XX:XX Discovering: yes
[NEW] Device 4C:65:A8:D2:31:7F MJ_HT_V1
Check for MJ_HT_V1 or similar entries, those are your sensor.
To use your Mi Temperature and Humidity sensor in your installation, add the following to your configuration.yaml file:
  - platform: mitemp_bt
    mac: 'xx:xx:xx:xx:xx:xx'
    monitored_conditions:
      - temperature
mac
(string)(Required)
The MAC address of your sensor.
(list)(Optional)
The parameters that should be monitored.
Default value:
[“temperature”, “humidity”, “battery”]
temperature
Temperature in C at the sensor’s location.
humidity
Humidity level in % at the sensor’s location.
battery
Battery details (in %).
name
(string)(Optional)
The name displayed in the frontend.
force_update
(boolean)(Optional)
Sends update events even if the value hasn’t changed.
Default value:
false
median
(integer)(Optional)
Sometimes the sensor measurements show spikes. Using this parameter, the poller will report the median of the last 3 (you can also use larger values) measurements. This filters out single spikes. Median: 5 will also filter double spikes. If you never have problems with spikes, median: 1 will work fine.
Default value:
3
timeout
(integer)(Optional)
Define the timeout value in seconds when polling.
Default value:
10
retries
(integer)(Optional)
Define the number of retries when polling.
Default value:
2
cache_value
(integer)(Optional)
Define cache expiration value in seconds.
Default value:
300
adapter
(string)(Optional)
Define the Bluetooth adapter to use. Run hciconfig to get a list of available adapters.
Default value:
hci0
Note that by default the sensor is only polled once every 5 minutes. This means with the median: 3 setting will take as least 15 minutes before the sensor will report a value after a Home Assistant restart. Even though the hardware is able to provide new values every second, room temperatures don’t change that quickly. Reducing polling intervals will have a negative effect on the battery life.
Full example
A full configuration example could look like the one below:
    name: Kids Room Temp
    force_update: true
    median: 1
      - temperature
      - humidity
      - battery
