Little Swan
Support for devices by Little Swan in Home Assistant is provided by the Midea integration.
Little Swan devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Midea integration.
To add the Little Swan integration to your Home Assistant instance, use this My button:
From the list, select Little Swan.
Usage information
For more documentation on how to use Little Swan in Home Assistant, please refer to the Midea integration documentation page.
