Xiaomi Philips Light
The xiaomi_miio platform allows you to control the state of your Xiaomi Philips LED Ball Lamp, Xiaomi Philips Zhirui LED Bulb E14 Candle Lamp, Xiaomi Philips Zhirui Downlight, Xiaomi Philips LED Ceiling Lamp, Xiaomi Philips Eyecare Lamp 2, Xiaomi Philips Moonlight Bedside Lamp and Philips Zhirui Desk Lamp.
Features
Philips LED Ball Lamp, Philips Zhirui LED Candle Lamp and Philips Zhirui Downlight
Supported models: philips.light.bulb, philips.light.candle, philips.light.candle2, philips.light.downlight
  • Power (on, off)
  • Brightness
  • Color temperature (175…333 mireds)
  • Scene (1, 2, 3, 4)
  • Delayed turn off (Resolution in seconds)
  • Attributes
    • model
    • scene
    • delayed_turn_off
Supported models: philips.light.ceiling, philips.light.zyceiling
  • Power (on, off)
  • Brightness
  • Color temperature (175…370 mireds)
  • Night light mode (on, off)
  • Attributes
    • model
    • scene
    • delayed_turn_off
    • night_light_mode
    • automatic_color_temperature
Philips Eyecare Smart Lamp 2
Supported models: philips.light.sread1
  • Eyecare light (on, off)
  • Ambient light (on, off)
  • Brightness (of each light)
  • Eye fatigue reminder / notification (on, off)
  • Eyecare mode (on, off)
  • Attributes
    • model
    • scene
    • delayed_turn_off
    • night_light_mode
    • reminder
    • eyecare_mode
Supported models: philips.light.mono1
  • Power (on, off)
  • Brightness
  • Attributes
    • model
    • scene
    • delayed_turn_off
Supported models: philips.light.moonlight
  • Power (on, off)
  • Brightness
  • Color
  • Color temperature (153…588 mireds)
  • Scene (1, 2, 3, 4, 5, 6)
  • Attributes
    • model
    • scene
    • sleep_assistant
    • sleep_off_time
    • total_assistant_sleep_time
    • brand_sleep
    • brand
Please follow the instructions on Retrieving the Access Token to get the API token to use in the configuration.yaml file.
To add a Xiaomi Philips Light to your installation, add the following to your configuration.yaml file:
# Example configuration.yaml entries
light:
  - platform: xiaomi_miio
    name: Xiaomi Philips Smart LED Ball
    host: 192.168.130.67
    token: YOUR_TOKEN
    model: philips.light.bulb
host
(string)(Required)
The IP address of your miio light.
token
(string)(Required)
The API token of your miio light.
name
(string)(Optional)
The name of your miio light.
Default value:
model
(string)(Optional)
The model of your light. Valid values are philips.light.sread1, philips.light.ceiling, philips.light.zyceiling, philips.light.moonlight, philips.light.bulb, philips.light.candle, philips.light.candle2, philips.light.mono1 and philips.light.downlight. This setting can be used to bypass the device model detection and is recommended if your device isn’t always available.
Platform Services
Service light.xiaomi_miio_set_scene
Set one of the 4 available fixed scenes.
Service data attribute Optional Description
entity_id no Only act on a specific Xiaomi miIO light entity.
scene no Scene, between 1 and 4.
Service light.xiaomi_miio_set_delayed_turn_off
Delayed turn off.
time_period no Time period for the delayed turn off.
Service light.xiaomi_miio_reminder_on (Eyecare Smart Lamp 2 only)
Enable the eye fatigue reminder/notification.
Service light.xiaomi_miio_reminder_off (Eyecare Smart Lamp 2 only)
Disable the eye fatigue reminder/notification.
Service light.xiaomi_miio_night_light_mode_on (Eyecare Smart Lamp 2 only)
Turn the smart night light mode on.
Service light.xiaomi_miio_night_light_mode_off (Eyecare Smart Lamp 2 only)
Turn the smart night light mode off.
Service light.xiaomi_miio_eyecare_mode_on (Eyecare Smart Lamp 2 only)
Turn the eyecare mode on.
Service light.xiaomi_miio_eyecare_mode_off (Eyecare Smart Lamp 2 only)
Turn the eyecare mode off.
