LG Soundbars
The LG Soundbars integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control LG Soundbars from Home Assistant.
Supported devices:
  • Devices in the SK and SN range with Ethernet and/or Wi-Fi
To add the LG Soundbars integration to your Home Assistant instance, use this My button:
  • From the list, select LG Soundbars.
Supported operations
  • These devices support mute, volume control, source selection and mode selection.
