Joaoapps Join
The joaoapps_join
integration exposes services from
Join. In Home Assistant, the Join features are
divided up in two locations, the Join component, and the Join notify platform.
The notify platform allows us to send messages to Join devices, the component
allows us to access the other special features that Join offers. When in doubt, you can reference the API documentation this is based on.
In the configuration.yaml
file you need to provide the API key and device id
or name of the target device. You can find your device id and API key
here.
To set it up, add the following information to your configuration.yaml
file:
notify:
- platform: joaoapps_join
api_key: YOUR_API_KEY
device_id: DEVICE_ID
device_ids: DEVICE_ID_1,DEVICE_ID_2
device_names: DEVICE_1_NAME,DEVICE_2_NAME
joaoapps_join:
- name: NAME_OF_GROUP
device_id: GROUP.GROUP_NAME
The name parameter is optional but needed if you want to use multiple notification platforms. The platform will be exposed as service notify.<name>
. The name will default to notify
if not supplied. See the Notifications Component for more details.
Use only one of device_id
, device_ids
, or device_names
, this will determine the notification recipient(s).
notify:
device_id: DEVICE_ID1
device_id: DEVICE_ID2
The notify service has several optional parameters: icon
, smallicon
, image
, sound
, url
, notification_id
, category
, tts
, tts_language
and vibration
You can use them like so:
message: Hello from Home Assistant!
title: Home Assistant
icon: https://goo.gl/xeetdy
smallicon: https://goo.gl/xeetdy
vibration: 0,65,706,86,657,95,668,100
image: https://www.home-assistant.io/images/favicon-192x192-full.png
sound: https://goo.gl/asasde.mp3
url: https://home-assistant.io
notification_id: hass-notification
category: Custom Notification Category
tts: Notification from Home Assistant
tts_language: english
actions:
Netflix:
Tweet:
- Tweet from HASS!
Sleep:
The services exposed in the joaoapps_join
integration can be used with the
service data described below:
Service | Data |
joaoapps_join/ring | |
joaoapps_join/send_sms | {"number":"5553334444", "message":"Hello!"} |
joaoapps_join/send_tasker | {"command":"test"} |
joaoapps_join/send_url | {"url":"http://google.com"} |
joaoapps_join/send_wallpaper | {"url":"http://www.planwallpaper.com/static/images/ZhGEqAP.jpg"} |
joaoapps_join/send_file | {"url":"http://download.thinkbroadband.com/5MB.zip"} |
