Image Processing
Image processing enables Home Assistant to process images from cameras. Only camera entities are supported as sources.
ALPR
ALPR entities have a vehicle counter attribute vehicles
and all found plates are stored in the plates
attribute.
The found_plate
event is triggered after OpenALPR has found a new license plate.
# Example configuration.yaml automation entry
automation:
- alias: Open garage door
trigger:
platform: event
event_type: image_processing.found_plate
event_data:
entity_id: openalpr.camera_garage_1
plate: BE2183423
The following event attributes will be present (platform-dependent): entity_id
, plate
, confidence
Face
Face entities have a face counter attribute total_faces
and all face data is stored in the faces
attribute.
The detect_face
event is triggered after a Face entity has found a face.
automation:
- alias: Known person in front of my door
trigger:
platform: event
event_type: image_processing.detect_face
event_data:
entity_id: image_processing.door
, name
, confidence
, age
, gender
, motion
, glasses
scan_interval and optimizing Resources
Image processing integrations process the image from a camera at a fixed period given by the scan_interval
. This leads to excessive processing if the image on the camera hasn’t changed, as the default scan_interval
is 10 seconds. You can override this by adding to your configuration scan_interval: 10000
(setting the interval to 10,000 seconds), and then call the image_processing.scan
service when you actually want to perform processing.
- platform: _AN_IMAGE_PROCESSING_PLATFORM_
automation:
- alias: Scan for faces when motion detected
trigger:
- platform: state
entity_id: sensor.door_motion_sensor
to: 'on'
action:
- service: image_processing.scan
