IDrive e2
The IDrive e2 integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to use an IDrive e2
Before configuring this integration, you need to prepare your IDrive e2 account. This includes creating a bucket to store your backups and an access key with permissions to that bucket.
Create a new IDrive e2 bucket
- Log in to the IDrive e2 Management Console
. - Follow the steps on creating a bucket
in the iDrive documentation. - When prompted to define a bucket name, make sure it is unique: Name (for example,
home-assistant-backups-123456). - When adjusting the settings:
- Files in bucket are private: Enabled by default. It is recommended to leave it enabled.
- Versioning (optional): Lets you recover backups after Home Assistant deletes them, but it can increase storage costs. Disable this to allow permanent deletion based on retention settings.
- Make a note of the bucket name and region. You’ll need it later.
Create an access key
To create an access key that has access to the bucket:
. - Follow the steps on creating an access key
in the iDrive documentation. - When prompted to define a name, make it descriptive (for example,
home-assistant-backup). - When adjusting the settings:
- Access key expiry: Disabled by default. It is recommended to leave it disabled.
Access permission: Read and write (default).
- Allow deletion of objects: Enabled by default. It is recommended to leave it enabled.
- Allow bucket deletion: Disable this option (unchecked).
- Assign the access key to the bucket you created earlier.
- Make a note of the Access key id and Secret access key. You’ll need them when configuring the integration in Home Assistant.
Avoid using credentials that have more permissions than is necessary.
By limiting credentials to a specific bucket, you reduce risk and help keep your IDrive e2 account secure.
To add the IDrive e2 service to your Home Assistant instance, use this My button:
From the list, select IDrive e2.
menu. Then, select Delete.
