Hurrican Shutters Wholesale
Support for devices by Hurrican Shutters Wholesale in Home Assistant is provided by the Motionblinds integration.
Hurrican Shutters Wholesale devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Motionblinds integration.
To add the Hurrican Shutters Wholesale integration to your Home Assistant instance, use this My button:
Hurrican Shutters Wholesale can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select Hurrican Shutters Wholesale.
Usage information
For more documentation on how to use Hurrican Shutters Wholesale in Home Assistant, please refer to the Motionblinds integration documentation page.
