Hitachi Hi Kumo
Support for devices by Hitachi Hi Kumo in Home Assistant is provided by the Overkiz integration.
Hitachi Hi Kumo devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Overkiz integration.
To add the Hitachi Hi Kumo integration to your Home Assistant instance, use this My button:
Hitachi Hi Kumo can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select Hitachi Hi Kumo.
Usage information
For more documentation on how to use Hitachi Hi Kumo in Home Assistant, please refer to the Overkiz integration documentation page.
