Green Planet Energy
The Green Planet Energy integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides real-time electricity pricing data from Green Planet Energy, a German renewable energy provider. It fetches hourly electricity prices and provides various sensors for energy optimization and monitoring. It visualizes the prices so that you can adapt your power consumption and shift it to cheaper hours.
You don’t need to have an account with Green Planet Energy for this integration to work. However, the integration will probably only make sense if you are their customer with a dynamic energy tariff. For the setup, no additional information is required.
To add the Green Planet Energy service to your Home Assistant instance, use this My button:
  • From the list, select Green Planet Energy.
Sensors
The Green Planet Energy integration provides the following sensors.
Current price
  • Current price: The current electricity price in EUR/kWh
Statistics
  • Highest price today: The highest electricity price for the current day
  • Lowest price day: The lowest electricity price during day hours (6:00-18:00)
  • Lowest price night: The lowest electricity price during night hours (18:00-6:00)
Disclaimer
This plugin is third-party and not offered by Green Planet Energy eG.
