Google Maps
The google_maps
platform allows you to detect presence using the unofficial API of Google Maps Location Sharing.
Setup
You need two Google accounts. Account A is the account that has to be set up to share its location with account B. Account B is used to fetch the location of your device(s) and will be connected to this integration.
- You first have to setup sharing of the location of account A through the Google Maps app on your mobile phone. Share your location with account B. You can find more information here.
- Next, you have to retrieve a valid cookie from Google, while being logged in with account B. Log in with your credentials of account B on Google Maps with a PC with Firefox or Chrome. Make sure to use the
.com
TLD (e.g., maps.google.com), otherwise the cookie won’t be able to provide a valid session. After you have properly authenticated, you can retrieve the cookie with either Export cookies for Firefox (make sure that “Prefix HttpOnly cookies” is unchecked) or get_cookies.txt for Chrome/Chromium. - Save the cookie file to your Home Assistant configuration directory with the following name:
.google_maps_location_sharing.cookies.
followed by the slugified username of the NEW Google account (account B).- For example: If your email address was
[email protected]
, the filename would be:.google_maps_location_sharing.cookies.location_tracker_gmail_com
Note for existing location sharing users
If you already have other people sharing their location with your existing Account A and do not wish to ask them to also share their location with a new Account B. Simply repeat the steps above to obtain a valid cookie from Google for Account A. Then add both accounts to the device tracker configuration (don’t forget to include the multiple cookie files, one for each account being added to the integration).
device_tracker:
- platform: google_maps
username: "ACCOUNT_A_EMAIL"
username: "ACCOUNT_B_EMAIL"
To integrate Google Maps Location Sharing in Home Assistant, add the following section to your configuration.yaml
file:
device_tracker:
username: "YOUR_EMAIL"
Once enabled and you have rebooted devices discovered through this integration will be listed in the known_devices.yaml
file within your configuration directory.
They will be created with indentifiers like google_maps_<numeric_id>
. To be able to properly track entities you must set the track
attribute to true
The email address for the Google account that has access to your shared location.
Sometimes Google Maps can report GPS locations with a very low accuracy (few kilometers). That can trigger false zoning. Using this parameter, you can filter these false GPS reports. The number has to be in meters. For example, if you put 200 only GPS reports with an accuracy under 200 will be taken into account - Defaults to 100km if not specified.
