Google Air Quality
The Google Air Quality integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides Air quality data through the Google Air Quality API.
You need an API key. Follow the instructions in the Google developer documentation for creating an API key. Additionally, you have to create a Billing Account. At the time of writing this documentation, Google allows 10,000 API calls per month for free.
Important
This integration polls every 60 minutes. Here is an overview about how many API calls are performed per month in dependence of the amount of coordinates:
Coordinates API calls per month
1 800
2 1,600
3 2,400
4 3,200
5 4,000
10 8,000
12 9,600
Consider each restart of Home Assistant is an additional API call, per coordinate/entry.
You can set up a budget for your billing account. This does not limit your costs, but you can get an alert when you reach the budget. You may want to set up disable billing with notifications. This can still produce costs between incurring costs and receiving budget notifications.
Make sure to monitor the cost. If you make too many requests, you will be charged for it. The integration cannot monitor it for you.
To add the Google Air Quality service to your Home Assistant instance, use this My button:
  • From the list, select Google Air Quality.
Configuration parameters
API key
The API key, which is described in the prerequisites.
HTTP Referrer
Specify this only if the API key has a website application restriction.
Name
A display name for this location, such as Home or Work.
Latitude
Latitude of your location.
Longitude
Longitude of your location.
Custom local air quality index
If you want to set a custom local Air Quality Index (AQI) during the setup of the integration you can do this in this optional section.
Enable custom local AQI
Turn on to use a custom local AQI for this location.
Country
The country of your location.
Custom local AQI
The custom local AQI.
Supported functionality
Sensor
The integration will create the following sensors, if they are available for the selected region. For your local air quality you can find more details here
  • Universal Air Quality Index (UAQI)
    The global air quality index provided by Google. Ranges from 0 (worst) to 100 (best).
  • UAQI Category
    Descriptive category for UAQI. Possible values include: Excellent air quality, Good air quality, Moderate air quality, Low air quality, Poor air quality.
  • UAQI Dominant Pollutant
    The pollutant that most significantly influences the UAQI value. Possible values include: PM2.5, PM10, Ozone (O₃), Nitrogen Dioxide (NO₂), Sulphur Dioxide (SO₂), Carbon Monoxide (CO)
  • Local Air Quality Index
    A regionally calibrated AQI value.
  • Local Category
    Descriptive category for the local AQI. The values can differ from the ones set as UAQI Category.
  • Local Dominant Pollutant
    The pollutant that most significantly influences the local AQI. The values can differ from the ones set as UAQI Dominant Pollutant.
  • Ammonia (CH₃)
    Ammonia concentration.
  • Benzene (C₆H₆)
    Benzene concentration.
  • Carbon Monoxide (CO)
    Carbon monoxide concentration.
  • Nitrogen Dioxide (NOâ‚‚)
    Nitrogen dioxide concentration.
  • Nitrogen Monoxide (NO)
  • Non-methane hydrocarbons (NMHC)
    Non-methane hydrocarbons concentration.
  • Ozone (O₃)
    Ground-level ozone concentration.
  • PM2.5
    Particulate matter smaller than 2.5 µm in diameter.
  • PM10
    Particulate matter smaller than 10 µm in diameter.
  • Sulphur Dioxide (SOâ‚‚)
    Sulphur dioxide concentration.
      • Devices
      • Hubs
      • Services
      • Integration entries
  3. To confirm, select Delete.
