GeoNet NZ Volcano
The GeoNet NZ Volcano integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you use a GeoJSON feed provided by
New Zealand’s GeoNet
Entities are generated and updated automatically with each update
from the feed. Each entity defines the volcanic alert level
The data is updated every 5 minutes.
The material used by this integration is provided under the Creative Commons Attribution 3.0 New Zealand (CC BY 3.0 NZ) license
We acknowledge the New Zealand GeoNet project and its sponsors EQC, GNS Science and LINZ, for providing data/images used in this integration.
To add the GeoNet NZ Volcano service to your Home Assistant instance, use this My button:
From the list, select GeoNet NZ Volcano.
State attributes
The following state attributes are available for each entity in addition to the standard ones:
| Attribute | Description |
| latitude | Latitude of the volcano. |
| longitude | Longitude of the volcano. |
| external_id | The external ID used in the feed to identify the volcano. |
| activity | Volcanic activity. |
| hazards | Most likely hazards. |
| distance | The distance in km or mi to Home Assistant’s location. |
| last update | Timestamp of the last update from the feed. |
| last update successful | Timestamp of the last successful update from the feed. |
Full configuration
geonetnz_volcano:
radius: 100
latitude: -41.2
longitude: 174.7
