FRITZ!Box Net Monitor
The fritzbox_netmonitor sensor monitors the network statistics exposed by AVM Fritz!Box routers.
It might be necessary to install additional packages: sudo apt-get install libxslt-dev libxml2-dev python3-lxml If you are working with the All-in-One installation, you may also need to execute also within your virtual environment the command pip3 install lxml; be patient this will take a while.
To use the Fritz!Box network monitor in your installation, add the following to your configuration.yaml file:
  - platform: fritzbox_netmonitor
host
(string)(Optional)
The IP address of your router, e.g., 192.168.1.1. It is optional since every fritzbox is also reachable by using the IP address 169.254.1.1.
Default value:
169.254.1.1
name
(string)(Optional)
Give the sensor a friendly name for in the front-end.
Default value:
fritz_netmonitor
The following statistics will be exposed as attributes.
Attribute Description
is_linked True if the FritzBox is physically linked to the provider
is_connected True if the FritzBox has established an internet-connection
wan_access_type Connection-type, can be DSL or Cable
external_ip External IP address
uptime Uptime in seconds
bytes_sent Bytes sent
bytes_received Bytes received
transmission_rate_up Current upstream speed in bytes/s
transmission_rate_down Current downstream speed in bytes/s
max_byte_rate_up Maximum upstream-rate in bytes/s
max_byte_rate_down Maximum downstream-rate in bytes/s
The sensor’s state corresponds to the is_linked attribute and is either online, offline, or unavailable (in case connection to the router is lost).
This integration does not support "Fritz!Box 6490 Cable" with FritzOS 6.87 installed.
